Error code -2147467259 in robotics hardware setup
hello
i have problem in robotics hardware setup for starter kit 2.0 real time in deploy phase the error code is
nisyscfg.lvlib:Initialize (Helper).vi<APPEND>
<b>Complete call chain:</b>
nisyscfg.lvlib:Initialize (String).vi:6610001
Install all available SW.vi
Wizard.vi
please help me to complete my project
(5,714 Views)
What did the rest of the error message say? The part where it says, "Probable Reason..."
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(5,688 Views)
hi Mike
Thank you for your interest in this subject
This picture shows the problem
best regard
(5,656 Views)
MAX,
Does this happen every time you try to deploy to it? Did you try resetting the device and redeploying?
J. Calvert
Applications Engineering
(5,616 Views)
hi
Yes.I resetting the device and deploy ,every time the same problem
best regard
(5,608 Views)
Sometimes a firewall can block the deployment of files to your target device. Can you try turning off your firewall or any antivirus software and try again?
(5,577 Views)
