Showing results forĀ
Search instead forĀ
Did you mean:Ā
Error code 28 LabVIEW Null menu
The error cluster of my VI indicate that the error 28 : LabVIEW Null menu occur in it, but when I open the block diagram  of this VI to see which subVI cause the error, the error doesn't reappears anymore and everything is OK.
Afterward, if I close my erroneous VI and run it again. The error Reappears. I try a MASS COMPILE but I still have the same problem. So I have 2 questions.
1) What can cause the apparition of the error when I run my application normally and not when I open the VI block diagram.
2) What can cause the Error: 28 : LabVIEW Null menu.
Thank you for your answer
Gpaito
(4,431 Views)
Post the VI's if possible.
(4,428 Views)
What do you mean post the VI's ?
J.-P.
(4,289 Views)
This is over 1 year old ?!?!   Smiley SurprisedSmiley Surprised
What i mean is that you can add your VI to a meesage so we can have a look at it
Message Edited by K C on 02-26-2007 09:31 PM
(4,284 Views)
I know it’s over one year old, but it’s an intermittent problem. And I will post the VI this problem return, because for the last 2 months everything is fine.
J.-P.
(4,279 Views)
OK, sorry for my reaction  Smiley Wink  but in the first message is looked like a urgent problem.
I'll wait for the VI
(4,274 Views)
