Error code 3 and scale.cpp error Labview 2009 SP1
Hello..
I have big problem with my vi, i get the generic error code 3 also scale.cpp  error. I use Labview 2009 SP1, it means my labview already installed with f3 patch. I tried mass compile, i got the message that my vi is bad, but nothing fixed. Everytime i open my vi, labview will closed automatically. I can not do anything with this problem. I don't have the backup file for this vi, it means if i can not fix this i have to create again from the beginning. Only this vi has the problem, another vi are fine. Please if there someone who can help me. I also attached my corrupted vi.
(2,770 Views)
I was able to open it in LabVIEW 2011 and I back-saved it to 2009. You can try to see if it opens. If not, well, start rewriting.
Learn to use source code control.
(2,757 Views)
