Error code:EABO - I/O operation aborted
I tried to run a vi. which is created by our group's former member to control keithley 2400.
I got a "EABO - I/O operation aborted"  error.  I don't know why, could someone give me suggestions for this trouble?
The labview I used is Labview 2019.
Message 1 of 9
(3,833 Views)
Have you tried the solutions mentioned here?
Message 2 of 9
(3,800 Views)
Hi yhphycn,
you are using some ancient GPIB functions in your VI.
Since 10+ years you should use VISA functions instead.
Have you tried to use the latest instrument drivers found in the IDNet for your device?
Message 3 of 9
(3,797 Views)
Thanks for your reply. I have not solve it.
Message 4 of 9
(3,749 Views)
 You think the GPIB functions is very old?
So, I should change to visa now?
Another question, why it also doesn't work even I replace it with new GPIB commands?
Message 5 of 9
(3,746 Views)
Hi yhphycn,
Because something is wrong.
Could be software, could be hardware - you didn't tell so much about your setup so far…
Have you tried the Keithley2400 driver available in IDNet?
What is your hardware setup?
Message 6 of 9
(3,743 Views)
I use labview 2019.
Keithley 2400 driver is installed.
I use Keithley Instruments KUSB-488B with NI compatible driver.
"Error code:EABO - I/O operation aborted" showing in the subvi.
The whole/main labview Vi file is created by other person a few years ago.
I just want to slightly modify it since I am not an expert in labview now.
Please give me some suggestions.
Message 7 of 9
(3,738 Views)
so you are using a Keithley USB-2-GPIB converter: in my experience you run into problems when using those old GPIB functions.
I recommend to use the most current version of the Keithley2400 driver with VISA function calls instead.
Message 8 of 9
(3,734 Views)
OK, thanks so much for your help.
Message 9 of 9
(3,730 Views)
