Error code received while deploying on target
hello!
we are trying to deploy our standalone application but after rebooting of target pc [pxi (NI 8176 controller)], it display following error code:
loading error 57.
This can be seen on attachement.
(2,908 Views)
Hey,
As of LabVIEW 2011, SSE2 compiler optimizations were introduced as a build option in build specifications.  However not all target hardware supports these SSE2 optimizations, including the PXI-8176.  You will need to disable these optimizations under the advanced settings of your build specifications.  You can read more about this in the knowledge base article I've linked below.  I hope this helps!
Why Does my Real-Time Executable Fails to Load on Certain Real-Time Targets?
Isaac S.
(2,863 Views)
