Error compact RIO 9014
Dear All,
I'm using labview 2018 32 bit to program compact RIO 9014. I have installed LabVIEW 2018 32 bit, LabVIEW FPGA, LabVIEW Real Time and NI RIO driver. I created a blank project and added cRIO-9014 in the new target and device option. The problem is that I can't see the module under the Chassis in the Project Explorer as well as FPGA target and I can't select the programming mode. If I go on the properties of the chassis it says Unexpected.
Please help me fix this
Thank you
(2,182 Views)
It is good that your NI Distributor system is seeing the modules.
How to find modules in NI MAX.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P7gtSAC&l=en-US
You have to create the FPGA module in LabVIEW project yourself. This link shows how to:
https://zone.ni.com/reference/en-XX/help/371599P-01/lvfpgahelp/adding_an_fpga_target/
(2,132 Views)
in the labview project i can not add chasis 9114
Can you give me the solution ? i have reinstalled many time
(2,113 Views)
Hi there,
I think this link will help you: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019P6zSAE&l=en-US
(2,111 Views)
