Error:-could not find LV service port from ServiceLocator In VL2009
Dear All
      When i am running NI example finder in LV2009. The error comes
Could Not find LabView service port from ServiceLocator. You Will not be able to browse by Directory Structure.
How i can over come from this.
-Vishnu
(3,120 Views)
(3,108 Views)
Thanks I could solve that problem
Now i have another error for DSC module.
20583iEAF8D34F28E5E37E
Can you please help me to solve this.  Due to this error, i could not study Boiler Example.
When i run Boiler Example.Vi  it is not taking data from share variable engine and not up data variable.
--Vishnu
(3,100 Views)
(3,095 Views)
    I have done that. First time Boiler project worked and showing data on Boiler Example.Vi, same time the same error poped up. The program run fine till i pressed OK button on error window.
--Vishnu
(3,085 Views)
