Error creating plot
Hi
In my GUI I am using a mathscript node to generate a plot (simply using plot function).
When I am running the VI, that plot is generated(opening in separate window).
But when I am making the .exe and running the same, that window is not getting opened.
Where am i possibly going wrong in the build spec properties.
(3,213 Views)
Is that functionality supported in executables? Why are you plotting in the msthscript node? LabVIEW would likely do a better job.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,183 Views)
