Error : datamgr.cpp, line 1233
During VI (.vi, .ctt) edition, i got the follwing error :
- Erreur interne fatale : "datamgr.cpp", ligne 1233
Labview version 7.0.
Why this error occurred ?
(Windows XP, pack 2)
(3,308 Views)
Generally you will find error description for occured errors on line "xxx" here.
Please attach an example programm for reproducing this issue. Which version of LV you are using? Are you maybe using type def. controls ?
Message Edited by Indiana on 05-11-2005 08:48 AM
(3,303 Views)
There is no information about datamgr and line 1233 in the link.
I use LabView 7.0 on Windows XP, pack 2.
I use type def control.
I can not attach an example programm for reproducing this issue (i can not reproduce this issue again).
Ben.
(3,297 Views)
Ben.
Hello Benoitb,
A LabVIEW internal error "xxx.cpp" provides an indication that a condition exists that prevents LabVIEW from continuing execution.
In your case, I can not reproduce the problem, so I suggest you to Mass compile your VIs by using LabVIEW tool :
You can do that by going to "Tools»Advanced»Mass Compile".
For more information about this tool :
http://digital.ni.com/public.nsf/websearch/AA97C01071D7CF678625695100582F40?OpenDocument
Hope this help.
Best Regards,
Sanaa T
National Instruments France
Sanaa T.
(3,281 Views)
