Error : datatype.c line 148
While trying to create a controll to a VI and then save i get the following
error-message : datatype.c line 148. Then LV shuts down.
Does anyone know how to fix this ?
Øystein.
(2,864 Views)
Do you have a particularly large number of controls and indicators on your
front panel? If so, then you are probably running into a limitation inherent
to your version of LabVIEW. If you contact NI's technical support with the
datatype.c and line 148 info, they should be able to help explain the situation
more fully and suggest some workarounds.
I'll also see if we can get information on this problem into our KnowledgeBase.
Best Regards,
John Lum
(2,864 Views)
