Error during installation "Insert Source"
Hello all,
I've recently downloaded LabView 30 day trial for my school work. When it finished installing I got an error message. You can find the whole error here
I used the search engine and google, I did not find anything related. And the message box is quite vage for me. I hope you can help me. If I get it to work by some divine intervation, I will post result here, incase others end up looking up months/years later
[LabView, 64 bit. 2011]
(4,811 Views)
I fixed it. Nevermind
(4,804 Views)
I have the same problem as you did, would you mind providing me you solution here.
Thank you
(4,774 Views)
Hi Hsinhung
The way to resolve that problem is selecting the option Decline Suppot. This is because the error says that select the folder were the device drivers are. If you are downloading the trial version from www.ni.com, you are only downloading the software LabVIEW. The drivers will help you to comunicate with hardaware.
If you want to use your software with hardware, I invite you to go to http://www.ni.com/drivers/ to find the drivers that you will need.
In this other link you can find the new devices drivers http://joule.ni.com/nidu/cds/view/p/id/2602/lang/en
Regards
Julio Mena
(4,759 Views)
