Error for LabVIEW PDA Module Version 8.5
Hi all
        I am face on with problem when i try to do the LabVIEW PDA Module Version 8.5 Tutorial which is include in labVIew software package.All my lincence status also activated and do install all the accessories that i need.I follow all the steps by tutorial sheet.But i still face on with problems, so now i would like to uninstall my LabVIEW software and reinstall again.The error is as shown in attach file. i want to know is there any problem if i uninstall my software? If anyone can show me why the error is? The technician said even though the error come out, just close and wait for about 5 min.After 5 min already the emulator will be come out.But mine haven't comeout.So please any one can show me?
Thanks a lot
Best Regards
Nyan Lin
PS: The tutorial that i do is as shown in attach file.
(3,495 Views)
Hi Nyan,
It looks like your missing some files from you VI libraries that are preventing the application from successfully building.  Did you recently install LabVIEW and the PDA module?  What order did you install your software?  What you want to do when installing software is to install or upgrade LabVIEW, then install/upgrade any modules after upgrading LabVIEW.  After that you would install the NI-DAQmx driver and lastly you would install your hardware.  I would hold off before uninstalling and reinstalling unless you did not install in the order that I mentioned above because that process can be time intensive.  I'll dig around in my file structures and see if I can find where you are missing those files.
Stephen S.
1 Test is worth 1000 expert opinions
(3,467 Views)
Hi Nyan.
I went through this whole tutorial and successfully built the VI and ran it.  It seems like a file problem so you may need to reinstall the PDA module.  I did find some information on a very similar error though, you should try to do what this Knowledge Base instructs you to do.  It might just be that small setting that is causing the application builder to not recognize those files.
Stephen S.
(3,447 Views)
Hi Stephan
                  Thanks for giving your time for me. I am a new LabVIEW PDA Module user.And I have to do it because of my final year project.I am student from Nanyang Polytechnic (Singapore). I never use labVIEW software and LabVIEW PDA Module software before.This is my first time. The software that i have is LabVIEW Version 8.5. So as what you say is i need to reinstall my the whole LabVIEW PDA Module and all start again? Then i know that for PDA Module i need to download Virtual PC2007.But what else i still need to install? The Window Mobile 5.0 emulator and the rest softwares is it include in the LabVIEW PDA Module software package? If not, please let me know which software i still have to download? Then i go and check the software status that i have and the lincense status is as shown in attach files.Thanks for giving your time and help me.
With Regards
Nyan Lin
(3,438 Views)
Hi Nyan,
Just use the windows add and remove programs menue to remove only the PDA module.  Then reinstall it along with the Virtual PC2007 software.  Everything you need should be included in the PDA module.  Thanks and have agreat weekend.
Stephen S.
(3,423 Views)
