Error generating vi's form .dll file using import shared library
 Hello All,
I am working with a serial manipulator which has its interface in Labview. I would have to generate vi's by using "import sharedlibrary .dll" as shown by the Serial Manipulator's company at the link http://www.robai.com/assets/LabviewRemoteCommandInterfaceGuide.pdf  and use them to operate the manipulator. Vi's were generated fine and interface was working fine. I had to reinstall Labview and after that when I try to create vi's from dll's, errors are generated (please see the attachment DLL_report) and also when I try to open the main vi provided by the company to operate the manipulator (which contains the vi's generated from .dll file), the following error pops up(please see labview_interface_dll_error).
I copied the 'dll file' to 'C/ Windows/System32' but to no use.
I could also see that in the call library function node path for the dll is specified correct (please see path_call node.png) i.e, ecLabviewRemotecommand.dll is located in the path specified in the call node.
Please help me out and let me know if any details are needed.
Thanks and Regards
(3,355 Views)
Did you have to install another driver or program in addition to LabVIEW to use this manipulator (NI-VISA, NI-DAQmx, or another driver)? If that is the case, you can try reinstalling that as LabVIEW needs to be installed before any drivers, so a reinstall of LabVIEW may be confusing the driver.
will.i.am10
(3,316 Views)
