Error group for error codes
I need to get meaningful error group based on error codes like FPGA, RT, Database, LIN and so on for my error handling. Now I threat them as LabVIEW error group. Is there a list avaliable somewhere?
(5,343 Views)
(5,335 Views)
Here is one list for the basic LabVIEW errors, but there are many more lists. https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/errors/general-labview-error-codes.html
The Error Ring on the Dialog & User Interface palette will also show categories of errors.
(5,332 Views)
Error ring is preciselywhat I am looking for, it has error groups defined. I assume it will read this errors based on what toolkits are installed on Labview?
(5,307 Views)
And context.
Abnormal conditions may be errors in RT but only warnings in Windows.
Some example that I have seen is "open thermo-couple" is one example.
Some error codes for SoftMotion are not defined under Windows but are defined under RT.
Ben
(5,297 Views)
I think I have extracted what I need from ErrorRing xnode.
I don't see function that will give me familly name based on error code so I will have to make some lookup table.
Vi attached if anyone needs that in future
(5,293 Views)
double post
(5,293 Views)
