Error handling
Hello everyone !!
please help me
i'm getting 3 errors error when i executing the code normally.
but when I executing the same code with highlight execution it is working fine.
so how can I solve my issue;
thanks....
Message 1 of 12
(4,220 Views)
You should  not be running your DB operations in parallel. The reason it works with execution highlighting turned on is that execution highlighting basically runs things as a single thread and the DB calls are no longer being executed in parallel.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 12
(4,202 Views)
I closed all the database operations but still I'm facing same error.
please help me sir.
Message 3 of 12
(4,190 Views)
the following is my code.
Message 4 of 12
(4,176 Views)
As was already pointed out to you, your database operations are happening in parallel.  You need to chain the operations to run in series.
Message 5 of 12
(4,100 Views)
No, you attached a picture of your code.  If you had attached your code (a file with the extension ".vi"), we could have sent you a picture (or maybe even the code, saving you some work) of the specific steps you need to do, in case you didn't understand what we meant by "in parallel".
Bob Schor
Message 6 of 12
(4,090 Views)
please tell me how to change in detail.
thanks......
Message 7 of 12
(4,083 Views)
thanks for correcting me.
i'll share with .vi
please let me know the correct solution.
please help me.
Message 8 of 12
(4,081 Views)
Use Data Flow!  Pass your errors from one VI to the next.  This will create data dependencies and therefore set the order of when the VIs are ran.
Message 9 of 12
(4,068 Views)
Boil down LabVIEW to its very core: "Remember that a node executes only when data is available at all of its input terminals and supplies data to the output terminals only when the node finishes execution."
If you apply that one sentence ruthlessly to your code, you will be on your way to efficient LabVIEW coding.  Apply that sentence to your code and you should be able to bend that VI to your will.
More on dataflow here.
Bill
CLD
(Mid-Level minion.)
Message 10 of 12
(4,037 Views)
