Error in Build Application (EXE)
There is an error is prompt as attached when I was trying to build the exe.
Both my Labview 2012 & Database toolkit are evaluation version.
I have no idea how to choose the different option as the error message mentioned.
Is there any alternative way to build the exe?
By the way, my PC still has the full activated version of Labview 8.5.1, can I get any assist from there?
Thanks.
(3,238 Views)
If you have the app builder and toolkit for 8.5.1, then use it. Otherwise, you'll have to purchase the toolkit or use something else. There have been numerous discussions on alternatives.
(3,233 Views)
Hi tantan,
                    If you have activated 8.5 then why you are not using this for building exe ?
Any specific reason ?
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(3,220 Views)
Hi Ranjeet,
Because all the vi are LV 12.0.
Since I have purchased the 8.5.1, if I want to use the database connectivity toolkit 2012 and activate it through my 8.5.1 product's serial number, is it possible?
(3,215 Views)
No its not possible.
Convert all the 2012 VIs in 8.5 and then try to build it.
--Ranjeet
(3,213 Views)
