Error in Compiling onto FPGA
When I try to compile my FPGA code generated from the FPGA wizard I get this error
An error occurred attempting to connect to this compile server.
Details:
LabVIEW: An exception occurred within the external code called by a Call Library Function Node. The exception might have corrupted the LabVIEW memory. Save any work to a new location and restart LabVIEW.
I already tried uninstalling and reinstalling xilinx
(3,426 Views)
Hi JJJschool,
What hardware and version of the compile tools are you using?
Have you tried building the project without the wizard?  Here is some more information if you're not familiar with that process.
Also, could you upload a screen shot of the error and a MAX Technical Report?
Dave C.
(3,395 Views)
Labview 12.0
Xilinx 13_4
I've only attempted to compile code created by the wizard
(3,383 Views)
Could you tell us what hardware you're using?  Hardware using Virtex II FPGAs require the Xilinx 10.1 compile tools.
Next, I'd recommend checking to see if port 3580 is being blocked by a firewall or antivirus software.  You can check by typing http://localhost:3580 into your web browser address bar.
If you have the right Xilinx tools and port 3580 is open, I recommend building your project without using the wizard and reattempting the compilation.
Let us know what you find.
Dave C.
(3,339 Views)
