Error in Image subtract
I have two images and I apply IMAQ subtract among these two. Image 1 is much brighter in intensity with respect to Image 2. But, I see a complete black image after the IMAQ subtraction. How can this happen.
Abhilash S Nair
Research Assistant @ Photonic Devices and Systems lab
[ LabView professional Development System - Version 11.0 - 32-bit ]
LabView Gear:
1. NI PXI-7951R & NI 5761
2. The Imaging Source USB 3.0 monochrome camera with trigger : DMK 23UM021
OPERATING SYSTEM - [ MS windows 7 Home Premium 64-bit SP-1 ]
CPU - [Intel Core i7-2600 CPU @ 3.40Ghz ]
MEMORY - [ 16.0 GB RAM ]
GPU - [ NVIDIA GeForce GT 530 ]
Message 1 of 13
(6,371 Views)
What are you subtracting from what? Maybe you get negative numbers, coerced to zero?
(sorry, I don't have IMAQ)
Message 2 of 13
(6,356 Views)
Image 2 subtracted from Image 1. No it is not zero. I removed the write IMAQ 2.vi and checked the images in the VI front panel. I can see the images. But when I write it to a file (bmp, jpeg, tiff or png) I see only black image.
Abhilash S Nair
LabView Gear:
Message 3 of 13
(6,354 Views)
Better Convert both the image into pixel array then subtract it. Later convert this to image.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 4 of 13
(6,329 Views)
What is a pixel array?
Message 5 of 13
(6,326 Views)
Its a equivalent 2D array of pixel that represent one image. Can be represented in U8, U16,I16 and Float.
As you said you dont have IMAQ so attching image for that
Here it is of array is 640X480 becasue of image of same size.
--Ranjeet
Message 6 of 13
(6,321 Views)
I am just saying that you should be more specific when using strange and unusual nomenclature. If you google "pixel array", you mostly get results about image sensors, which does not seem appropriate here.
I don't need a solution because I don't have a problem and you don't have to attach any images for me, derailing the thread in the process. The OP does have IMAQ. If you have an IMAQ solution to the subtraction problem, contribute, otherwise simply don't post.
Message 7 of 13
(6,317 Views)
Yes its a image pixels. I will be more careful next time
--Ranjeet
Message 8 of 13
(6,315 Views)
abikutn can also refer the image.
abikutn refer the attached VI for calculation of image to image pixel. Simlarly calculate for other and later use IMAQ array to image to convert the subtracted image pixel to image
In my attachment I am first converting image to image pixel and later image pixel to image. In your case input to IMAQ array to image will be subtracted image pixel array
--Ranjeet
Message 9 of 13
(6,309 Views)
I see that you are disposing of the images at the end of the code, which is good, but are you writing the image before that. Have you also checked what the values are in the bitmap, They may appear black but be between 0 and 10 for example. Use the colour picker tool in your drawing package of choice on your bitmap and see what the values are and if they change.
On your actual program are you acquiring 12 bit images that the camera is capable of. If so you will be acquiring 16 bit images and the dynamic display of the IMAQ indicator will come into play. You will also only be able to save correctly in PNG or TIFF.
Mike
Message 10 of 13
(6,299 Views)
