Error in MemoryManager.cpp
Hello
I build my application that continuously measures temperature from 4 thermal cameras and monitors if the temperature limit is not exceeded.I am writing to a file only when the camera is calibrated and when the limits were exceeded, but I did it also in old code that seamlessly work. What exactly is happening before the program crashes do not know because I do not watch the monitor for a few hours every second until it falls. But it should not happen nothing unusual because the cameras stare at a constant temperature.
I registred issue in MemoryManager.cpp. But in development environment Labview I dont register any problems or errors.
This issue have been appeared after few hours and I dont know where is the problem. I tried switched off firewall and antivir but it doesnt help.
Please have anyone any idea where can be problem?
Best Regards
Petr Vavra
(3,750 Views)
(3,736 Views)
