Error in NIScope read
The program works fine until yesterday, but today it seems not stable, sometimes gave error as the attached screen.
I tried the NIscope front panel, it(5133) works fine.
Any suggestion?
Message 1 of 11
(4,202 Views)
Have you searched the forum with the error code? Start here
Message 2 of 11
(4,198 Views)
Thanks, but I am only having one device and just simple data polling as attahced.
It may caused by not close the session properly. As attached, there are many sessions, some cannot close even I tried to make another simple program.
But I tried to start the system still not work. Unable to open the sample there since the version is too old.
May you give any suggestion, thanks.
Message 3 of 11
(4,193 Views)
You are right at this point. Try closing the session. If not possible try closing LabVIEW and re-launch LabVIEW. Quick try and post back
Message 4 of 11
(4,189 Views)
I restart the PC, unplug and plug the 5133, but still get seem error.
This time even use niscope or Max test cannot run any more.
Message 5 of 11
(4,177 Views)
After self test 2 times, it now works with NIscope front panel only.
Does I missing something, such as NIscope initiate acqusition.
Message 6 of 11
(4,174 Views)
Are you opening up multiple session and not closing it properly?
Message 7 of 11
(4,166 Views)
I just open one session and close it in the end in the attached DAQ2.vi
Message 8 of 11
(4,163 Views)
Now seems know the error, when I open the signal generator and when there is signal coming in, the program works ok and no errrors occur.
But I am still not sure how does it happen and how to change my program.
Any suggestion?
Message 9 of 11
(4,155 Views)
Are you saying that the program now works and that when it wasn't working, you did not have a signal applied? If that's the case, then the error message is normal. Without a trigger event, there is no waveform captured so you are supposed to get a timeout.
Message 10 of 11
(4,135 Views)
