Error in actalization
i've got a great problem and haven't got any ideas.
my programm calculates the "number of rows" of the shown array (the "index display" is hidden).
The problem is if the array is expanded by the new calculation it doesn't work right.
The items which are expanded are displayed wrong.
i don't think that this is a programm error because if I minimize and maximize the window the array is shown right.
in the attached there is ascreenshot from my display
(the window was  pushed outside the displayed area of the screen till the third element of the array. when i pushed it back the third and fourth element is shown right).
is it possible to redraw a window?
markus
(2,744 Views)
The question is unclear. Maybe you should post a vi (after right clicking on the array and doing properties>make current value default).
Are you determining the array size using the Array Size vi? If not you should try it.
(2,732 Views)
