Error in date scaling in LabVIEW.
Dates seem to be shifted by one day when they are plotted. See attached VI.
(3,052 Views)
I don't understand what you mean by "shifted". The first date on the graph is 5/25 and the first date in the string array is 5/25. All of the other points in the graph seem to agree with the strings as well.
(3,052 Views)
On my computer which is running WIN2000 the first date in the array is 5/26 but the plotted data is at 5/25, and all of the subsequent dates are similarly shifted (see attached JPEG file). I checked my system date/time and it was indeed July 2. I even had someone else run this app on another computer and they got the same results as I did. ??????????
(3,052 Views)
Since the dates are the same when I run your VI (and with the same OS and LV version), I can only guess that it might have something to do with your local time/tdate settings.
(3,052 Views)
