Error in dependency
Hi all,
My labview NXG2 code was working for a long time with good output. I installed new features from NI by mistake. I attached the list of features I installed. Even I did not find the features in the program list where I can uninstall them. Maybe Labview NXG2 also upgraded to NXG as you can see in the list . Now my program is showing few errors "Error in dependency". If I click on the error one native library tab open. I attached both here. As I could undersatnd from the error analysis is that the library path has changed. I don't know how to fixed this problem out. Please help me regarding this problem.
(2,776 Views)
Error2.png shows a lot of errors related to "NIVISA" in their title.
Did you install the VISA drivers?
As for where to install and uninstall, it seems everything is now handled through NI Package Manager.
(2,721 Views)
thanks for your answer. I checked every possible way to solve this problem. but later,  i have realized that the library file was missing or somehow damaged. So, I have uninstalled and again reinstalled the labview. now its working again.
(2,691 Views)
