Error in drawmgr.cpp when running VI
I have a VI which is trying to draw the following items on the screen -
6 graphs
2 x realtime plots from DAQ
2 x Outputs from limit testing VI (= 4 waveforms + 2 additional waveforms)
2 x delayed graphs i.e. data from previous iterations.
all sampled at 200Hz
There is also 2 x colour ramps.
Every time i run the Vi i get a drawmgr error, i ahve tried everything on the ni website so far to no avail! I can run the VI successfully with only 1 of each item listed above (the second graphs are a repeat of a different channel).
Am i just asking Labview to draw to much on the screen? The screen is at 1024X800, the same error occurs at lower colours and lower resolutions too.
Will upgrading the v
ideo card/memory have any effect on this?
Any information would be appreciated.
(2,793 Views)
If you get a drawmgr error, note the exact message & look at
www.ni.com/failure .
Mark
(2,793 Views)
