Error in file "/usr/share/applications/fedora-gnumeric.desktop": "zz-application/zz-winassoc-xls" is an invalid MIME type ("zz-application" is an unregistered media type)
Trying to install Labview on a linux (fedora 16) machine, I get:
the following error:
   5:labview-2010-desktop   ########################################### [ 71%]
   6:labview-2010-appbuild  ########################################### [ 86%]
   7:labview-2010-pro       ########################################### [100%]
./INSTALL: line 293: return: -1: invalid option
return: usage: return [n]
Any idea?
Thank
(2,717 Views)
Hello p.dupre,
did you try with a clean fresh system?
Or with the latest version of fedora?
The issue is not known, so it must be something special about your system.
Peter
(2,659 Views)
