Error in labview,
Hello friends,
I have written a labview code for controlling a furnace.
It controls and records temperature of the furnace during heating and cooling.
When I run the code, I encounter the following error:
Error -1073807339 occurred at VISA Read in ET24XX Utility MODBUS RTU Receive Message.vi->ET24XX Utility Write To Register.vi->ET24XX Utility Multiple Write To Registers.vi->ET24XX Utility Multiple Write To Registers in Configuratin Mode.vi->ET24XX Instrument Configuration.vi->FURNACE.vi
Would you please help me how to overcome it?
Thank you in advance,
(3,076 Views)
@nimanikpoor wrote:
Hello friends,
First, attach Furnace.vi, and the ET24XX routines.  As there appear to be more than three of them, I recommend you compress the folder containing all of your VIs (and the ET24XX routines) and attach the ZIP file.  It is a little difficult to read a novel wearing a blindfold.
Bob Schor
(3,074 Views)
