Error in linker.cpp line 2357
While trying to load a vi with many subvi's in llbs, labVIEW cannot find a subvi called fixit.vi (a VI I wrote and stored in an llb) so it asks me to find it. Every choice during the loading process causes this error: ignore subvi, stop, continue without, browse then select or cancel. I can open the VI that LabVIEW cannot find, fixit.vi, and can create a new vi and drop fixit.vi in as a subVI and the new vi opens without a problem. I have tried opening the toplevel VI on many machines as well as opening other vi's that call this subVI, but all react the same. I've also tried rebooting the computer. Please help.
(2,623 Views)
Two other things you can try. Open the subVI, fixit.vi first. Then
with it still in memory, open the toplevel VI. If this works, sav
e.
If this doesn't work, it may be time to send the VI to support. This
will be easy if it doesn't require the subVIs to reproduce the problem.
Greg McKaskle
(2,623 Views)
