Error in property node
Hi
The example "Meas Duty Cycle-buffered-Finite.vi" has errors related to writing the property of the property node. (Please refer to the attachment) I am using Labview version 8.2. Can you please advise. Do i have to update my version of Labview or is there other problems? Thanks a lot.
Charles
(3,526 Views)
Post ur VI.
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
(3,525 Views)
(3,511 Views)
Your VI opened up just fine for me in LV 8.6.1 without any errors.
Are you sure you have DAQmx installed on your PC?  You said you are working in LV 8.2, but what is the latest version of LabVIEW you have installed on your PC?
(3,504 Views)
Your VI opened up fine for me in LV 8.2 With DAQmx 8.7.
Balaji PK (CLA)
(3,501 Views)
