Error in read (write) file module
When I use a module read (or write) file, in the dialog to choose file, I press Cancel then occur an error to stop program, how can I fix that error?
(2,657 Views)
You look for that particular error (if my memory is correct, it is error 42) and clear it.
(2,656 Views)
