Error in reading binary files
@Bob_Schor wrote:
Look up the Help documentation for Application Directory.  Notice it is different for Applications (.exe) than for VIs in the Development Environment (and different for developing in a Project and "in the raw").
That is because it is meant for using with relative paths.  So you do need to make sure your files keep the same relative path to your executable as your project when developing.
Message 11 of 20
(3,073 Views)
Hi pincpanter,
When i try to upload a file from the list i have. I can able to upload only three files (5,6,7) from down. I can't upload the remaining files(1,2,3,4). All the files are in the same path.
Please find the attachment
Message 12 of 20
(3,056 Views)
Guys,
Explaining in brief, I have 7 binary files to read the data from. When i am executing the VI i can able to read the data from all the 7 binary files.
when i am building the exe and trying to open the binary files, It throws the dialog in the error case i have given.
Chaitanya
Message 13 of 20
(3,051 Views)
Hi Chaituc
It seems there may be problem with
1) File path : Build .exe with allow debug mode enable and run exe and highligh execution inside exe by clicking on Operate---> Debug application or shared library..
2) Binary file write function: problem may arise on how you write binary file. if you write binary file with array of elements and you specify only single element to read as a read data type reference then error occurs.
CLD
Message 14 of 20
(3,045 Views)
Hi chaituc,
You were asked to show more error information and you got examples on how to get them.
Did you follow our suggestions so far?
Again:
Which path does your EXE try to read?
Which error number did you get?
Message 15 of 20
(3,040 Views)
When you have persistent and inexplicable problems in the middle of a large, complex LabVIEW routine that uses Classes and other Fancy Stuff, you can (probably) "figure out what's wrong" by writing a little test routine.
I recommend that you write a Stand-Alone program that does the following:
  • Asks the User to choose a File, using the same code that you are now using to find the .pcf files 1..7 you want to use.
  • Open the file and do enough "checking" to convince yourself that you successfully read it.
  • Verify that you and open and read all of the files.
  • Once this works, build an executable of this simple routine and repeat the test.  If it works, try to understand why, when you embed the same code in your larger program, it fails!  [It may have something to do with a "name clash" with a definition in a Class or Library somehow not properly being picked up -- this seems unlikely or maybe "impossible" to me, but who knows?].  If it works, try putting such code back in your Big Program.
In any case, you will now have a very simple routine that you can share with us, along with some data files (of course, if it works, you won't need to share it, but if it fails, we'll be eager to help and to figure out "Where's the Bug?").
Bob Schor
Message 16 of 20
(3,026 Views)
@Gerd.  Look at the error ring  add the filename and error code, and source to the custom errors format e.g. Error %d occurred at %s trying to read file %s.
On a phone so no snippet.   Mr. Ko can earn a kudos for one.
Message 17 of 20
(3,016 Views)
Hi Jeff,
so basically what I suggested in message #4?
@OP:  It would have been so easy to get a full error description…
Message 18 of 20
(3,013 Views)
I'm kinda burned out today; only good for semi-witty remarks.  I think Gerd is on the right track, except you can use the error ring constant to translate it into "StandardLabVIEWError-ese" for ease of reading.
Bill
CLD
(Mid-Level minion.)
Message 19 of 20
(3,004 Views)
@GerdW wrote:
Hi Jeff,
Yes but much easier with an error ring, a Select wired to error, and a simple error handler.;D.
Message 20 of 20
(3,000 Views)
