Error in the Timing Violation Analysis
I've got an unexpected error after compiling a FPGA project:
The total delay of the path (8.32ns) smaller than the requirement (8.33ns) and the delay of the path, which consists of the SumSign VI (7.08ns) and a Non-diagram component (0.69ns) should be 7.08ns + 0.69ns = 7.77ns and not 8.32ns. Does anyone have an explanation where the missing time is coming from?
Im using Labview 2011 (32bit), Xilinx 12.4 Compiler, Windows 7
(3,208 Views)
I can't exactly help but I got a timing error today also where the timings simply didn't add up.
I'm using LV 2012 SP1 and Xilinx 13.4.
Shane.
(3,176 Views)
I have never seen it before. Could you post your VIs?
Regards, Fabian
(3,112 Views)
I certainly can't.  It would mean exposing our and others IP which we are contractually unable to do.
Shane.
(3,106 Views)
