Error in unzip.vi
    Following error occured while trying to execute "Unzip.vi" in LabVIEW 8.5.
' Error 2 occurred at System Exec.vi. Command was "touch 08031518182009 "PTAStationSettings.ini"" '
I checked couple of post in the past related to this, but found no soultion.
Do any one have the solution for this issue?
-Sankar.
(3,590 Views)
Did you try to contact local NI?
support.india@ni.com
- Partha ( CLD until Oct 2027 🙂 )
(3,579 Views)
Accepted by topic author Sankar369
Hi Sankar
This is a known issue. It was fixed in LabVIEW 8.5.1. If you are not able to upgrade to 8.5.1 there is this open source library.
Sorry for the inconveniance.
Best Regards
David
NISW
(3,574 Views)
Partha,
      Yes, I did .. waiting for the reply from NI too...
-Sankar
(3,573 Views)
Hi David,
        The issue got resolved after installing LV 8.5.1.
Thanks for the support..
-Sankar
(3,559 Views)
Hi Sankar
You're welcome, happy it worked out for you
/David
(3,553 Views)
