Error indicating could not complie VI
Error indcates: Code could not be generated correctly for this VI.
I am trying to use the Matlab Code icon and have imported the code I need ...now it won't run.
Please help.
Bryan Howard
(3,130 Views)
Must be your Matlab code?
(3,125 Views)
The matlab code I am using is copied from an ISO standard an runs fine in Matlab. Any other suggestions. Has anyone else had trouble with Labview's Matlab Script Icon?
(3,122 Views)
I meant, it might be helpful if you pasted your Matlab code. If you have
existing Matlab code working, find out where it breaks.
"bhoward" <x@no.email> wrote in message
news:1148605807337-370585@exchange.ni.com...
> Matlab Script Icon?
(3,122 Views)
Are you sure you're using the MATLAB Script Node?  I've only seen the "code could not be generated correctly for this VI" error message when using the MathScript node.  I believe the MATLAB Script Node has a gray border, while the MathScript node has a blue border.
-D
P.S. - Posting a sample VI demonstrating the problem would, of course, help answer most of the questions people are asking you.
(3,118 Views)
