Error installing NI Package Builder
I have an error when i try to install NI PAckage Builder :
Could you help me ?
Have a good day,
Message 1 of 8
(2,517 Views)
Hi Arnaud,
Make sure you follow the troubleshooting steps found in this link: An Error Occurred While Installing a Package in NIPM - NI
Let us know if the problem persists,
Fort
Message 2 of 8
(2,498 Views)
Thank you for your answer, but i have always the same problem.
More details in logs :
===== 2022-Sep-10 14:00:08.302697 =====
Exception in ni::pkgclient::TransactionBase::StartInternal. Error code: -125083
Request type: 30
-125083: Une erreur a eu lieu à l'installation d'un paquet : ni-package-builder-core-x86 (22.5.0.49190-0+f38)
File: source\nipkg_client\pkgclient\PluginInteraction.cpp
Line number: 258
Additional error information:
-125441: L'exécutable a renvoyé l'erreur '-532462766' après avoir exécuté la commande d'exécution personnalisée 'path='"\\?\C:\Program Files (x86)\National Instruments\Package Builder\NipbCli.exe"', options='-r''.
File: E:\dev\_r\9\nipkg\source\shared_agents\Base/ErrorHandler/ErrorInfo.h
Line number: 327
Message 3 of 8
(2,475 Views)
Thanks for providing the error log, Arnaud.
Have you tried using the offline installer? What about older versions (e.g. 20.6)?
Message 4 of 8
(2,452 Views)
Yes I tried with lof of older version, and an offline installer but i have always the same error.
In Windows Event Log Management i see theses error.
Message 5 of 8
(2,447 Views)
It works with the Ni Package Builder V19.0.1 not after.
Message 6 of 8
(2,425 Views)
Hi arnaudmartin -
Some unhandled exception is occurring early on launch of nipbcli.exe and nipbeditor.exe in a separate thread. We have never seen this type of error reported to us, but we did see this type of issue during development of 19.6, but obviously you are seeing it now.
The only way to debug this is to get more detailed information. The log information that you have shared is helpful but not detailed enough.
Questions/Suggestions:
  1. I assume you are on a French localized OS, but what is the OS version and bitness?
  2. I am assuming yes based on the above conversation, but can you please confirm that you are seeing the same error launching NIPB Editor with 20.1 and that latest 22.5?
  3. Can you check the NIPB log files located "%localappdata%\National Instruments\NI Package Builder\Logs" to see if there is any additional call stack information? Can you share that log with the forum or send to me directly?
  4. Do you have a version of Visual Studio and/or .NET SDK installed? If so, do you have the Microsoft's Fusion Log Viewer application located in a directory like this? "C:\Program Files (x86)\Microsoft SDKs\Windows\v10.0A\bin\NETFX 4.6.2 Tools\x64\" The files are FUSLOGVW.EXE and FLOGVWRC.DLL (in a "1033" subdirectory).
  5. If you have the Fusion Log Viewer, you can:
    • Launch the viewer elevated as administrator
    • Use the "Settings" button to enable the option "Log bind failures to disk"
    • Then launch NIPB and let it exit
    • Click the Refresh button in the viewer to see what is logged.
    • You can double click on any line in the viewer windows to display the details in a browser window.
    • Example of use shown below:
  6. If you can do the above, could you share the details for each item logged with this forum or send to me directly?
Scott Richardson
https://testeract.com
Message 7 of 8
(2,412 Views)
Thank you so much for your help.
I repare my Windos OS, and i reinstalled Labview, and now i haven't any problem.
Have a good day,
Message 8 of 8
(2,330 Views)
