Error kernel.cpp line 144 on exiting an EXE
We have a distributed TCP/IP based control system in LV 6.1 running on W2K. Occasionally we have TCP read errors and when this occurs we end up having to reboot the application(s). We got the kernel.cpp 144 error when we exited out of one EXE. I cannot find any information on this error. Does anyone have any inof on this error? Causes? Things to check?
TIA, Mike Ashe
(2,925 Views)
Hello Mike!
I have searched our internal databases here, and we do not have any documentation relating to the kernel.cpp error line 144.
When you get the TCP read errors, do you get error codes associated with those errors, or do your applications just freeze? Also, does this just happen when you are in the run-time (EXE) environment?
As of LabVIEW 7.0, there is an error report that is generated when LabVIEW experiences a *.cpp crash, and there are no reports of this line number in our databases, so it is possible that whatever problem exists in your application has been investigated and fixed in the later versions of LabVIEW.
If you have any more information I would be happy to look into it!
Colin C.
Applications Engineering
National Inst
ruments
Colin Christofferson
Community Web Marketing
Blog
(2,925 Views)
