Error loading FlexRIO 14.0
While trying to load FlexRIO 14.0 (latest driver download) it failed with following error message.
.\ConfigInfo.cpp(2434): InstallerError 10007
Fatal Error. Unable to load a resource DLL.
Unable to load the custom resource file C:\temp\14.0.0\NIFlexRIO\Bin\data0009.dll because Windows Error 126: The specified module could not be found.
while attempting to load the resource DLL C:\temp\14.0.0\NIFlexRIO\Bin\data0009.dll
(4,933 Views)
Hi SunshineDesign,
Do you mean that this error occurred when trying to install FlexRIO 14.0, or when you tried to open program that calls the FlexRIO driver (after installation)?
If the installer is failing, I would recommend downloading a fresh copy of the installer file here: http://www.ni.com/download/ni-flexrio-14.0/4997/en/
If the driver is failing to load after installation, I would recommend repairing the installation, or uninstalling the current installation and reinstalling after a fresh download of the installer from the link above.
Let me know how it goes!
Best,
(4,891 Views)
Kevin it failed on install. I show the message I got. 13.2.1 installed fine.
(4,858 Views)
