Error loading ..\Labview7.1\vi.lib\DAQ\vdaq.dll
My problem is, that i don't find the dll called vdaq.dll normally located at ..\Labview7.1\vi.lib\DAQ\vdaq.dll
Therefore I can't load a LabView-Project of my friend which is in holidays now...
I searched with google and didn't found the dll. Maybe one of you can help me and provide this dll to me or can give me a link....?
Thanks a lot!
Greetings R.Abt
(3,908 Views)
Hello LabViewFreak:
I think your friend has mistakenly misspelled it.  I think it should be "lvdaq.dll".
You might want to locate the library function that is looking for this file and correct the spelling.
I hope this helps.  Please inform me if you have any other questions.
(3,902 Views)
Thanks for your answer!
As I see now, the call is for lvdaq.dll instead of vdaq.dll. Sorry for the missinformation!
This lvdaq.dll is at the specified location but LabView can't load it. I get the following Error Message, when I open the vi:
"Error loading "C:\Program Files\National Instruments\LabView 7.1\vi.lib\Daq\lvdaq.dll". A dynamic link library (DLL) initialization routine failed."
The Error Message also appears, when I Right-click on the Call Library Function node and select Configure and then select the dll.
Would be great if someone can help me to solve this problem!
(3,905 Views)
Hello LabViewFreak:
It's either there's a problem with your driver, or there's a problem with the parameters. Could you please try updating your NI-DAQ driver? The location of the driver might be found here:
http://www.ni.com/dataacquisition/software/
OR
http://digital.ni.com/softlib.nsf/websearch/CF7ECCEA4C4CC7DE86257038004D88AE?opendocument&node=132060_US
If it is still not working, could you please attach the vi. Or at least the image of the dialog from "Call Library Function".
(3,893 Views)
After installing the software package from [link removed] the program worked perfectly!
Thanks a lot for your advice!
Greets R.Abt
Message Edited by LabViewFreak on 07-25-2005 12:00 PM
(3,883 Views)
