Error log
thank you very much Fred for your efforts ,
but your solution is for me not so clear .. can you plz explain how did you solve my main problem ..
thank you again
Regards
Message 11 of 13
(1,036 Views)
this is an example of an error that happend .. try to add the path of this text file to your code and see how the fields have been displayed..
Message 12 of 13
(1,030 Views)
  • Save error : when you save error in the csv file delimited by comma (for example). the data appear differents cellules of excel (not in the same cellule). I sent you the code to save in previous message, try to use it.
  • Read error : after saving, use the vi of my last message to select and display the error code and source.
2.
But, if you want to use your file to display error code and source :
Read your csv file
Use element of palet String (match pattern for example) to separate the code and source and displays.
I advise you 1. But if you want to continuous with 2., try to built a VI and let me know if you have another question.
Fred.
Kudos are welcomeSmiley Wink
Message 13 of 13
(1,025 Views)
