Error memory.cpp line 638
My application stops activity at the frontpanel with the message: "Error, memory.cpp, line 638"
The program still is running but communication via visa crashes!
When clicking OK the whole program crashes!
Thank you
(2,785 Views)
The error you receive is an error in the code of the .dll, such as writing past the end of the memory allocated for an array.
The following links are forum-posts describing this issue:
http://forums.ni.com/ni/board/message?board.id=170&message.id=100477&requireLogin=False
http://forums.ni.com/ni/board/message?board.id=170&message.id=121851&requireLogin=False
http://forums.ni.com/ni/board/message?board.id=170&message.id=107367&requireLogin=False
I hope they can help you solving your problem!
Christian, AE Germany
(2,767 Views)
