Error message NIPathDir property while installation
we are facing an error while installation of Lab VIEW 8.2.1 on windows vista. Each time an Fatal Error message appears ;
"fatal error   NIPathDir property....is undefined"
Please tell me the solution for this error.
Altaf
Message 1 of 14
(5,157 Views)
Hi Altaf
Only the LV version 8.5 is certified for windows vista.
Lars
Message 2 of 14
(5,155 Views)
Message Edited by Altaf on 09-19-2007 06:55 AM
Message 3 of 14
(5,150 Views)
Hi Altaf
please send me a screenshot which shows the error message
Lars
Message 4 of 14
(5,146 Views)
Message 5 of 14
(5,130 Views)
here is screen shot
Message 6 of 14
(5,127 Views)
Hi Altaf
thank you
I will search for information and post back later
Lars
Message 7 of 14
(5,129 Views)
Hi Altaf
I found following entrys which may help you fixing the failer.
Why Do I Receive a 'Fatal Error: Required NIPathsDir ...' Message when Running a National Instruments Installer?
http://digital.ni.com/public.nsf/allkb/FEC14156DCF364908625733E004E7A01?OpenDocument
Dont know if you have a 64 bit version of windows vista:
Installing LabVIEW on Windows Vista x64 Edition
http://digital.ni.com/public.nsf/allkb/E9B4EA0143514DCB8625725D0050680A?OpenDocument
post bag with your emprovement
Lars
Message 8 of 14
(5,113 Views)
Hi Lars,
Thanks a lot
I made all these cahnges in Vista's documents setting but problem still persists. One thing is that in Vista, there is teh foldername "Documents" not "My Documents"..!! But I also tried both name in I created the folder name C:\Users\My Documents
Even then it doesnt work.
Thank u once again.
Altaf
Message 9 of 14
(5,083 Views)
Hi Altaf,
Something that would also be helpful would be to run the installer with the logging option, and post the resultant log file.  You can generate a log like this:  setup.exe /log logfile.txt
- Wes
Message 10 of 14
(5,069 Views)
