Error message and crashing of LabVIEW 5 when controlling K-Teams Khepera robot
I have the gripper turret attached to K-Team's Khepera 1 Robot and use the K-Team provided LabVIEW VI's to control the arm movement or gripper. Every so often I get an error message after the VI runs and LabVIEW has to shut down.
Does anyone know why this is? I dont' know whtehr you will know the exact cause but maybe what the error meassage below means. I am using LabVIEW 5.0 and the error message is shown below and in the attached file.
Sam
LABVIEW caused an invalid page fault in
module LABVIEW.EXE at 0137:0076cc3b.
Registers:
EAX=00000004 CS=0137 EIP=0076cc3b EFLGS=00010212
EBX=00000074 SS=013f ESP=01a6fd68 EBP=01a6fd74
ECX=00000001 DS=013f ESI=0323c498 F
S=31bf
EDX=000000f4 ES=013f EDI=00000000 GS=013f
Bytes at CS:EIP:
f3 a5 5e 5f 59 8b e5 5d c3 57 06 1e 66 8e da 66
Stack dump:
0323c498 030b5b31 00000000 01a6fee4 006b4f21 0323c498 00000000 00000004 030b5b30 00000007 0323c0bc c10745e4 01a6fdd8 bffa4633 03076ece 03076e44
(2,668 Views)
I'm not an expert per say but this could be a Windows corrupted hard disk fault.
Perform System Backup!!!
Empty re-cycle bins
Delete Temporary files
Run disk check
Defrag hard disc
reboot
Defrag hard disc
Rationale
A page fault is either memory or memory being paged to hard disk. An error in allocation raises this issue. I have seen it most often when the hard disk is heavily fragmented and or mis-allocation of hard disk space as a result of the aforementioned and Microsoft Word leaves temporary files around that have caused these kinds of issues.
There is a smaller possiblity that you have faulty memory but that's much less likely I would think.
Run a load of apps like Notepad with BIG files in them to cause the system to fill up and page to disk
then see if you get the same issue.
(2,668 Views)
Sam,
Unfortunately, this is not a LabVIEW error. You have a memory conflict within Windows. The previous response to your thread is an excellent evaluation of the problem. Because the error is a Windows registry-level error, I cannot provide support for this issue. You may want to contact Microsoft for further support after evaluating the possibility of this being a hardware issue.
Have a great day! I hope you get the robot back to a healthy state in soon time.
Kind Regards,
Joe Des Rosier
(2,668 Views)
