Error message from labview when trying to set up the DAQ assistant
I recieve a message from labview when I try to set up the DAQ assistant and select a channel to use. The error I get states "An exception occured within the external code called by a Call Library Node. This might have corrupted LabView's memory. Save any work to a new location and restart labview". Labview then freezes. I have reset the DAQ device in trying to slove this but I still get the same message. How do I solve this?? thanks - mars2006
(2,506 Views)
Hi Mars-
It sounds like your NI-DAQ installation may have become corrupted. I would suggest uninstalling and reinstalling the DAQmx 7.4 driver to correct this problem and ensure that you're up to date. This download is available here: NI-DAQ 7.4
If the problem persists you may want to uninstall and reinstall LabVIEW and then NI-DAQ in that order. The error message will usually give an indication as to which VI the error occurred in. Please let us know which VI is failing if you're unable to avoid the error with these suggestions.
Have a good day-
Tom W
(2,489 Views)
