Error message: incompatible image size when using IMAQ in image processing
I want to do low pass filter and convolution on an acquired image. When I connect the image to the VI, the message: incompatible image size appears. I have tried to set the border to 3 in IMAQ create, but it does not help. Anyone know how to solve this problem?
(3,232 Views)
Which particular VI is outputting this error? Did you try larger border sizes (5,7)? What is the exact error code and error string?
Yusuf C.
Applications Engineering
(3,232 Views)
