Error message on building application
I'm trying to build an .exe from a folder of VI's that link together, but when I try to build the .exe I get an error message which says 'Error 7 Cannot find Librarian Get Info.vi' I've added this VI to the list of VI's I'm trying to build from and the desktop and still I get this message!
(3,661 Views)
From the top level vi, you could try doing a File->Save w/ Options. Choose Development Distribution and Include library vis. Save everything to a new location. Restart labview, and try the build from the new location.
2006 Ultimate LabVIEW G-eek.
(3,661 Views)
OK, thanks, but how do I add the contents of the library as dynamic VI's without having to add them one at a time? Is this the best way of adding 80 or so VI's that call each other?
(3,661 Views)
What version of LV are you using?
This was a bug in earlier versions that was fixed:
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/862567530005f09e862567d10077407a?OpenDocument
and also:
(3,661 Views)
Using LV 6i
(3,661 Views)
If the library vis are called by the top level vi, they'll be included in the save w/ options if you tell it to include vi.lib files.
If this really is a new occurance of the bug, i'd report it to an NI Software Engineer, unless anyone else on the board has any ideas or has seen this before.
(3,661 Views)
