Error message re: MAX
I have just installed LabVIEW and MAX onto a computer but when I go to "Configure" on the front page of LabVIEW I am getting an error saying MAX cannot be loaded and that it may not be installed but I have installed it.
Any advice?
(2,679 Views)
Laura,
I would suggest removing MAX (Measurement and Automation Explorer) using the add/remove programs from within Windows. I would then firstly try a reinstall of the software. Maybe obtain a new copy of the software.
Generally this gets installed with a driver i.e. NI-DAQ.
Can you supply further information on the version of LV, the driver your installing etc. This will help me narrow down whats happening if the re-install (after uninstalling MAX) doesn't work.
Kind Regards
Steven Bird
(2,657 Views)
