Error message
I think the confusion may stem from the fact that they're using the "LabVIEW <-> GPIB" example, which doesn't use VISA - it uses the straight GPIB functions.
Message 11 of 13
(765 Views)
Yes, you are right. VISA and GPIB confusion.
When I use the VISA read and write function its working fine.
But in HFS9003 VI (from NI) it uses GPIB function to read and write  that's were the error happens.
Message 12 of 13
(753 Views)
You have to modify your address string as Dennis noted if using the GPIB functions and you are using a board with an id of 1 (or anything that's not 0). The Help file for the GPIB functions says:
When there are multiple GPIB Controllers that LabVIEW can use, a prefix to address string in the form ID:address (or ID: if no address is necessary) determines the Controller that a specific function uses. If a Controller ID is not present, the functions assume Controller (or bus) 0.
Message 13 of 13
(750 Views)
