Error messages
Could you tell me how to do it please?
Message 71 of 143
(1,515 Views)
Hi 99,
When you want to process all array elements inside your stae machine then it doesn't make any sense at all to index the first element before the loop and only wire this single element to the loop…
Re-read the whole thread.
Do all the Training courses that has been mentioned several times by now.
Learn to program in general, not just specifically LabVIEW…
Message 72 of 143
(1,510 Views)
In the courses they do not explain how to use the array in a state machine. I am asking you over and over again because I don't understand what each one tells me. Each one tells me one thing. I'm just asking you how to use that array because they don't explain it in any course
Message 73 of 143
(1,507 Views)
Hi 99,
it was explained in this thread, what you should implement in your statemachine.
When you don't understand those very basic steps then you need to learn LabVIEW (even more/better).
As you really don't show any improvements in the last months it doesn't make sense to explain the same stuff again and again. Good luck on your career as a (LabVIEW) programmer!
Message 74 of 143
(1,499 Views)
what has not been clearly explained is the use of that array
Message 75 of 143
(1,496 Views)
Hi 99,
it has been explained here or here or here or here or …
Message 76 of 143
(1,508 Views)
That was explained here. I don’t know how much plainer it could be than this thread without doing the work for you, and that’s not what people are on this board for.
Message 77 of 143
(1,506 Views)
in neither does it specify how to increase the index with the counter. Send a screenshot if it was connecting +1 at the input of the index and they said no. So how do I increase it ???
Message 78 of 143
(1,505 Views)
Hi
Is it like this?
Message 79 of 143
(1,475 Views)
Closer, but still no.
You only want to increment the index of the array whenever you achieve your position.  Not on every iteration of the while loop!
Don't forget that for each case of the case structure, you need to have an output for every tunnel.
Message 80 of 143
(1,470 Views)
