Error number 3134 has no text (?)
I am running a relatively simple VI with a Measurement Computing DAQ that reads temperature signal. Sporadically, I get this error message but am having trouble to find out the cause as there is 'no text' as appeared. Anybody has any tip for this? Thanks in advance,
(1,097 Views)
That looks like a ULx issue.  You should probably give Digilent support a look (https://digilent.com/shop/support/#channels).
(1,082 Views)
A link to the ULx Driver for LabVIEW Help file is found here.  On the Measurement Computing site..  Unfortunately it is a *.zip so my android phone won't open it.
You will probably get re-directed there on you Diligent Forums cross post as well.  Tim owes you a doughnut for missdirecting you.
(1,056 Views)
Digilent and MCC merged.  The Digilent forum has a whole section for MCC (got ported over sometime in the last year).
(1,020 Views)
