Error occuring when opening file programatically?
I am trying to create a directory(ok) and then create a file from information obtained from a program(error). In this example i am calling the directory C:\TESTDATA\`serialnumber`\`type of test` and the file called `date``operator`.xls
However once the directory is created, an error occurs when i open the file to write my table into?
Can anyone help?
(3,261 Views)
Can you do two things to help us help you? First, save your vi's using the "Save with options" selection "Development distribution", as some us don't have the OpenG libraries installed, and two, give us the error code/message you are getting.
P.M.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(3,255 Views)
It also helps if you don't start an essentially duplicate thread. Those who have been following and working to help resolve this in one thread may not see the new one, and those who see this one won't know what has been tried suggested in the other thread.
P.M.
Putnam
LabVIEW Champion
(3,254 Views)
Go here
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
(3,247 Views)
Apologies for starting 2 threads. Created at different stages.
Anyway, i have attached my vi with save options included for those who don`t use OpenG.
(3,235 Views)
