Error on Formula Node :Error on line 1 is marked by a '#' character:
Hey!!
This is a part of my prog..
Whats the problem with the prog?
Error on line 1 is marked by a '#' character: "y=[#uvl*50+(ul+ull+utlll)*40+(um+umm+umm"
(6,020 Views)
I don't think LV likes '[]', stick to parentheses.
(6,010 Views)
Plus the "utlll"
Omar
(6,006 Views)
Hey I have corrected both the mistake.. What is the problem now?
(5,976 Views)
(5,976 Views)
you did not define "n" or "d". You can declare them in the formula node code, or even easier, just add outputs with these names.
(What is your obsession with formula nodes, why not use wires instead? This is LabVIEW! :D)
(5,969 Views)
Thanks a lot..
No obsession with formula node.. its just a  part of my prog.. so i thought this would be the way..
thanks..
P.S.:I' m just a beginner..
(5,965 Views)
